TakingThe5th wrote:
... but how much of that 6.4 liters will actually be delivered if you need it?
Last night I ended not being able to get fuel. I reset the trip odometer at the point where the mileage counter reached zero. I drove 30 miles home at which point the trip recorder said I'd used 6.4 liters. I had the fuel tank off my 2011 f350 which is identical to the '16. The tank is designed with a special sump in it that allows 100% of the fuel to be drawn from the tank.
I filled up when I got home which took 92.5 liters. The tank capacity is supposed to be 26 gallons or 98.5 liters. I maybe could have gone another 30 miles?
