hddecker
Jul 13, 2014Explorer
Golden_HVAC wrote:Farm Camp wrote:
Yah, it might be. The burning of propane will take oxygen from the space and produces carbon monoxide.
I would not run (edit: on gas) in a closed space with no ventilation.
Really?
So do you ever use a gas stove inside a home?
The stove burners are up to 12,000 Btu's each, while the oven is 30,000 Btu's in a house. Compare this to the 2,200 Btu's that a refrigerator uses in a hour, it would take 6 hours to equal one hour of boiling water on the stove at home.
The garage is well enough ventilated to give it sufficient fresh air to allow running the refrigerator overnight. You did mention the open door while you are going in and out of the garage, so you will be fine.
Now if you hear the CO meter going off when you get out there, I would not suggest taking a nap on the couch, but get out and let it vent a while. The CO meter is there for your protection, and if it is not going off, then you are perfectly safe.
Fred.
My home is quite a bit bigger than my garage, it also has combustion air designed into the mechanical systems.
Why is that the owners manual tells you to open a window when the oven is in use. I would guess that would be to allow oxygen in to replace that which is consumed by the oven/cooktop.
44,056 PostsLatest Activity: Nov 19, 2013
