Nvr2loud
Jul 14, 2014Explorer II
Golden_HVAC wrote:Farm Camp wrote:
Yah, it might be. The burning of propane will take oxygen from the space and produces carbon monoxide.
I would not run (edit: on gas) in a closed space with no ventilation.
Really?
So do you ever use a gas stove inside a home?
The stove burners are up to 12,000 Btu's each, while the oven is 30,000 Btu's in a house. Compare this to the 2,200 Btu's that a refrigerator uses in a hour, it would take 6 hours to equal one hour of boiling water on the stove at home.
The garage is well enough ventilated to give it sufficient fresh air to allow running the refrigerator overnight. You did mention the open door while you are going in and out of the garage, so you will be fine.
Now if you hear the CO meter going off when you get out there, I would not suggest taking a nap on the couch, but get out and let it vent a while. The CO meter is there for your protection, and if it is not going off, then you are perfectly safe.
Fred.
First off: I agree with you.
Secondly: I would NOT ever run a gas stove inside my house without a range hood fan (exhausted to outdoors) running. I don't like the idea of exhausting products of combustion into an enclosed space even when the calculations verify that there SHOULD be enough fresh air.
Thirdly: We had a horrible situation here in the fall, young boy left in a minivan overnight after the tent camping family arrived late at night. He was asleep in the van, so they left him there. They set-up the tent but left everything else in the minivan overnight. The propane powered cooler produced enough carbon monoxide to kill the young boy. There was no CO detector inside the van of course...
44,056 PostsLatest Activity: Nov 19, 2013
