Golden_HVAC
Sep 13, 2014Explorer
Hi,
Go ahead and run the A/C, it is fine. If it starts to leak, then level it up on blocks of 2X10" boards. I have a set of 4 layer boards, the top being 9.5" and each below it 4.5" longer and the front side cut at 45 degrees. I also carry a 2 level ramp, because it is not always that off-level. And a long board, so that if I need to raise the right side say 3 levels in the front and 4 levels in the back, I might also need to raise the front left 1 level. Yes it has happened.
When I start needing ramps on all 4 tires - I know that the wife is messing with me. . .
I even have leveling jacks, so the ramps are only used in extreme off level campsites, usually the ones still empty on a Friday night, or have a great view, such as looking over a cliff or something!
Fred.
Fred.
