jamnw
Aug 01, 2013Explorer
astraelraen wrote:
I am by no means an expert, but my 2008 trailer has a Dometic fridge that seems to work off 12v. The fridge has an auto and gas setting. If I leave it on auto and unplug I can go around and not hear any signs of gas or hear the click click of the pilot lighting. I don't remember the last time I set it to gas only, but I do remember hearing the "furnace" type sound.
None of the AC outlets in the camper work unless I am plugged into a generator or campground, so I assume I don't have an inverter?
The "auto" setting will switch between 120VAC and propane. The "gas" setting will keep it on gas constantly.
I can hear mine switch if I am very quiet. It's very quick, and the flame is very small.
Just push the gas only and listen.
I used to NOT use gas while traveling. If its a 3-4 hour trip and your refer is packed it will stay cold.
2 years ago I started using gas while traveling. High temps and a 10 hour ride, and my milk was warm! It took forever to cool the fridge after getting to the cg cause the evening temps weren't much cooler than the day.
44,068 PostsLatest Activity: Jun 01, 2026
