carringb
Jun 07, 2018Explorer
Boon Docker wrote:
Not sure how you would get a closed loop when using the inverter in the tow vehicle.
You are not using the trailer battery, you are using the tow vehicle battery.
If you are hooked up to the 7-way plug, the converter will attempt to charge both the trailer and Tow Vehicle. I'm not aware of any OEM that include a diode to the trailer charge circuit. If you're disconnected from the 7-way, it's not an issue.
