Iraqvet05's avatar
Iraqvet05
rusty frames common on older Silverados?
I've been looking at older Silverado 2500s. I've ran into 2 trucks with rusty frames and I don't mean surface rust, I mean scaly rust. The first truck was a 2003. It sat on a local lot for a while and when I came back to look at it, the dealer sprayed the frame with undercoating and it sold soon after. The 2001 I looked at today had moderate rust on the entire frame and it looked worse near the back cross-supports. It looked like that dealer also replace the rear bumper and it appeared to have a new, but undersized 5,000 hitch on it. Are rusty frames common with the early 2000 GMs or could they have just come from northern states that salt their roads more often?
  • Probably depends on road salt use in the area where the truck was driven. I'd guess that it might be used in Mo. A quick check on Google confirms that.
    BK
  • I own 2 2000 trucks, and are pretty clean. Suburban has 200,000 miles, and GMC sierra has 280,000. Im sure there is plenty clean ones and a few rusty ones depending on where parked and if ever cleaned and underbelly washed
