SoundGuy
May 24, 2016Explorer
whosgreg wrote:
I just bought a 2011 Silverado that already has a GM 7 pole blade connector. It has 4 grooves inside with the wide one on top. Our RV 7 pole plug won't fit in. It was too tight. Does anyone know where I can get the correct plug please? I looked in the internet and found nothing.
What you're describing makes no sense ... pretty well every trailer built these days is wired with the ubiquitous 7-pin Bargman connector. Likewise your truck should be wired with the matching (flat) 7-pin Bargman - there is no other option. Here are the pinouts for the 7-pin Bargman connector.
