JimK-NY
May 18, 2021Explorer II
Camper_Jeff_&_Kelli wrote:
The "Dufas" is happy with the results. No smell, no taste, just good clean drinkable water coming out of the TC water system. ....
The concern is that the water treatment does not give "good clean drinkable water". Not with a strong possibility of bacteria and mold still remaining in the system.
If you are determined to avoid household chlorine bleach, then Purogene is a good alternative. It is still chlorine based and just as effective. You also need to rinse it out of the system as you would with household bleach. The MSDS reads pretty much like you will find for bleach:
"Corrosive
Harmful if swallowed
Avoid Breathing vapor or spray mist
Causes moderate eye irritation
Remove contaminated clothing and wash clothing before reuse
Wash thoroughly with soap and water after handling
Handlers applying chlorine dioxide must wear gloves
This pesticide is toxic to fish and aquatic invertebrates"
