My 21 SSO Starcraft camper fridge works when on site and plugged into power-but when I have it home in my driveway and plug the 220 into a standard extension cord via an adapter the fridge will not wo...
Need clarification on what you are doing. Hopefully you have a 30A 120V RV and are using a standard 30A female to 20A male adapter plugged into a 120V household plug. If so then the adapter could be bad or no power at the plug and/or the plug is on a GFCI circuit that has tripped or the extension cord is bad. Or you are drawing over 20A and tripping the house CB.
If you are actually plugged into 240V then it tends to let the smoke out.
