WYDOIN's avatar
WYDOIN
RV Wallpaper Where to buy?
Hello All, I'm working on a 30' TT. I'm repairing some damage on the inside and need to locate the wood grain wall paper on some of the press board pieces I have replaced. Anyone know where I can find a wood grain wallpaper that will match? I've looked online, but nothing really matches. Thanks ahead!
Roger P.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    I'd check with a dealer that sells that brand. FWIW when I wanted to do some changes to my outback the dealer was very cooperative and gave me good prices on drawers, door fronts matching trim pieces, molding, and matching plywood for my trailer. they ordered it from Keystone and had it delivered with trailer deliveries to save on shipping.
  • One of the larger paint/decorating stores in a metro area may be able to supply what you want. The ones I frequent have books of different patterns and styles.
    donn0128,
    I have the bunkhouse look in my trailer. It is Luan paneling with a finish applied. It's not for everyone. :)
  • Wood veneer might be a better solution. It sure would improve the look.
  • Even if you are able to find the same pattern and color, it probably still will not match, as the wall paper in your camper has aged, faded, been exposed to camp fire smoke, cooking smoke, and water vapor. It's kind of like touching up the paint on a wall inside the house. After a couple years, no matter how hard you try, the new will always look out of place against the old.
    If you don't mind this, then keep searching. But after searching and you finally find it, you may still be disappointed with the end results. It might be easier, better and more satisfying to repaper everything. Here's your chance to really beef-up your camper if you want.
  • Why not call the mfg of the tt and ask or order it ?
    If you are not able to find a match and you're looking at what you need, i doubt anyone here would able to match it .
    Roger P.
    I doubt you are going to find something that matches, There are probably hundreds or thousands that they have used. Probably better just going over the old with something new.
    What year, make, Model?
