Good day all, I have a quick question that I think I know the answer too. I need to put a refer cooling fan behind my refer, I have no 12 volt source behind the unit so I need to know if it would ...
However you probably have 12volts going to the refer control board in back there. I doubt an extra .5amp would cause any problems. That line is probably fed from one of your 12 fuses in your power distribution panel.
