Good day all, I have a quick question that I think I know the answer too. I need to put a refer cooling fan behind my refer, I have no 12 volt source behind the unit so I need to know if it would ...
patkvm, I looked on the internet at the same trailer you have. I see that your refer is under the counter top. I think you'll be OK running a wire directly from the refer to the battery. Like was said before make sure you have an inline fuse in the wire.
