dannydimitt
Apr 29, 2013Explorer
S T tires
:)Here is the most informative post I have ever seen on ST tires, Thank You Shaowcatche of irv2.com for this information. As many of you have figured out I am a bit obsessive about information an...
dannydimitt wrote:goducks10 wrote:
Problem is unless you run 16" tires you only have one choice. Maxxis. Since everything else is cheap ST junk. Not that many people want to, or can upgrade to 16" tires. My theory is by the TT with the highest CCC and that will put less strain on tires, suspension and frame. Interesting reading though. Boils down to you get what you pay for.
:)Evan though the specs quoted were all for 16 inch tires, the numbers on the specs for 15 inch L T verses S T tires should be right in line with the 16's
Unfortunately there does not seem to be any LT tires any longer in
14 inch size. And I for one can not remember there ever being any LT's or load range c or d in 13 inch size.
