myredracer
Jul 17, 2018Explorer II
pianotuna wrote:Voltage is everything! Measure the voltage inside your RV when the AC unit is running. Installing a permanent voltmeter in an RV is highly recommended so you can always monitor it in your travels or at home.
Monitor the voltage inside the RV. As long as it stays above 107 you are golden.
I'd also add to make sure plug blades are always kept clean and shiny to ensure a good connection.
I assume the receptacle is a TT-30R wired at 120 volts and not 240 volts...
