NEOK's avatar
NEOK
Safety wire for jacks?
Has anyone rigged some type of safety wire or something to keep their camper jacks from accidentally dropping down while traveling?
  • I'm sorry I should have included that they are Happijacks. I hadn't considered the possibility that they could drop on their own until I read a post that it happened to someone. All of the posts have been helpful.
    Thank you
  • Photomike wrote:
    SidecarFlip wrote:
    I don't quite comprehend the jack leg falling. On my RT jacks, the leg is actuated with a ball screw and the lower leg at the top has a welded in insert that engages the screw so, the only way the leg could drop would be for the insert to fail or the screw failed at the top where the gears are and both would render the leg inoperable anyway. Never had one drop on 3 TC's (first was Atwood's, second was HJ and now RT. I guess anything can happen. Seems odd to me.
    There are also hydraulic jacks that do not use the screw system.
    The OP was not specific as to type so I assumed it was a ball screw jack.
    I've seen pictures of hydraulic units but only pictures. Thought that was something 'old school'.
    I believe if I had them (hydraulic jacks), I'd fab up something to keep them up as well. Hydraulics tend to 'bleed off' as a rule.
  • My thought is that if this is something that is even marginally common, we would hear about it more often.
  • I don't quite comprehend the jack leg falling. On my RT jacks, the leg is actuated with a ball screw and the lower leg at the top has a welded in insert that engages the screw so, the only way the leg could drop would be for the insert to fail or the screw failed at the top where the gears are and both would render the leg inoperable anyway. Never had one drop on 3 TC's (first was Atwood's, second was HJ and now RT. I guess anything can happen. Seems odd to me.
  • I did with some light aircraft wire and a couple clips. Saved me a few times. Thought I had a post about it but cannot find it. Total cost was around $10 if I remember correctly.
    This is close to what I did Jack wire
