buechlerj's avatar
buechlerj
Sagging slide
We have a 2007 Springdale 290CT with a 13' slide that has about 1/2" of sag in the middle. I talked to a local rv repair shop and they said their repair would be to remove the trim on the inside, jack the sag out of the roof and screw a piece of angle along the edge to support the roof. I think I could hide the angle on the underside by sliding it under the ceiling panel. Has anybody tried this and how did it work out. Thsnks, Joe.
  • How is an angle brace on outside area of roof going to remove a sag.....?
    Sagging in middle would require a brace across middle where the sag is.
    Even if sandwich design the pieces of sandwich should be solid (no overlapping seams between top pieces and bottom pieces)
    Other than water intrusion to weaken material OR seams lined up causing a weakened area...roof shouldn't sag.
    The bracing just doesn't sound like the correct repair...to me
    Guess Repair shop has experience with this type of problem
  • There is no sign of water damage. The repair shop told me the top of the slide was sandwich construction and he has seen some sag like mine.
  • That sounds like a band-aid fix for a slide out roof that has been damaged by water intrusion.....otherwise why is it sagging.
    Correct fix would be to remove slide out and replace roof with new wood and find/fix area where water seeped in.
    Have you contacted your INS. Company, had an adjuster check it out?
    We had to have the floor replaced in our slide out.......insurance covered.
    Took a week for material to be shipped from mfg. and then 2 days for repairs (remove trim, disconnect electrical, remove slide out, tear out floor, install new floor, re-install slide out, hook up electrical, re-install trim, caulk and let sit overnight to cure)
