HI all, I have a 2014 OutdoorsRV and my “sani flush” seems to be clogged. When I hook up the hose, turn on water and open the dump valve, nothing comes out. Clearly the hose has tremendous pressure....
Can you hear it spraying? When I last did mine. The water stopped coming out, then I heard a rush of water. It did it a couple more times.... Obviously, I had a "solid" damn somewhere that when the tank got some water in it, the weight of the water cleared it.
I use the geo method to keep my black tank clean, so I suspect I have not been putting enough water in the black tank when using it...
