HI all, I have a 2014 OutdoorsRV and my “sani flush” seems to be clogged. When I hook up the hose, turn on water and open the dump valve, nothing comes out. Clearly the hose has tremendous pressure....
This only happened to me once and I found a kink in the hose feeding the sprinkleer. My sprinkler is mounted to the side of the tank with screws easily removed. Yours may be the same. Worth a look
