Thanks again for all the input on previous post http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28109016.cfm Here are the scale numbers and spec’s Pick up (2001 Dodge 2500, 5.9 Cummins, ...
Your TW cannot be determined with those weights. The WDH applies some weight to the front axle and some weight to the TT axles. If you weigh the setup again without the WD bars applied, then the TW will be sum of truck axles with trailer on ball minus sum of truck axles unhitched. Your TW is pretty light. If it tows well, I wouldn't change anything. You are under all ratings.
