Atlee
Aug 16, 2017Explorer II
How did it move with the wheel chocks in place?
jjjandrbaker wrote:
I almost had a major disaster. It certainly put me into panic mode! I've been using a 10" stack of stabilizer pads under the tongue jack landing gear, ever since I got this camper. It takes forever for the foot plate to reach the ground. Someone told me to use the stack to shorten the distance that the motor has to drop it. I have had no problems. This time, everything went as usual. I brought the jack down with the foot plate in the center of the stack, unhitched, and pulled the truck forward. Then I was ready to level the camper from front to back. I went inside to check my level, came back to the tongue jack, started to lower the front end and noticed that the landing gear had slid, and close to half of the foot plate was hanging off the edge of the damned stack of pads! I knew I had to get the trailer back on the hitch STAT! But, when I pushed the button to raise the receiver high enough to go on the hitch ball, the foot plate slid some more! I got in the truck and backed it up, but I was so panicked I had to pull forward and try again about three times. I finally made myself calm down and do it right. I got it on the hitch, took that **** stack away, and brought the tongue jack foot plate down on a small board I keep for leveling. Disaster averted. I really don't know what would have happened if it totally fell off the support stack, but it couldn't be good!
