SoundGuy wrote:
Gdetrailer wrote:
I imagine the OP is doing something like Soundguy's pix
Which IS a HORIBLE IDEA since you are depending on not only the friction between all the blocking keeping things together but a very unstable high stack of small lumber which places the center of gravity very high on the stack..
There is no MECHANICAL CONNECTION BETWEEN THE JACK AND BLOCKS that can prevent that pile of lumber from tipping over!
Yet again you're entirely incorrect. As I detailed earlier in another thread on this same subject my trailer's front tires, both curb side and street side, sit on wheel pads to which chocks are firmly attached, so I'm using the weight of the trailer itself to firmly lock the trailer in place. :B
There is NO forward pressure on the tongue jack - NONE - and therefore your assertion that this technique is a HORRIBLE IDEA is 100% incorrect. It's actually an excellent method of assuring my trailer is locked down firmly on my sloped driveway. Fact is, you simply don't know what you're talking about. :R
The OP IS NOT using your "chock"..
Makes YOUR "pile" under the tongue a HORRIBLE IDEA.
Your "system" while "ingenious" someday will get someone else KILLED if they fail to ensure the wheels cannot move.. But, they ARE wheels and wheels CAN move even when you think they can't.
I would not bet my life under that kind of cribbing, would you?
I suspect the OP was not using your chock "method" but WAS using a PILE OF LUMBER IN THE SAME FASHION as your photo, which illustrates what I suspect the OP has been doing..
Besides, why take such chances when there ARE CORRECT TOOLS for the job.. The correct tools are the foot extension I posted and it is no more expensive than all that lumber and plastic blocks you use.
At work, using a pile of lumber in your fashion to hold a large heavy object up would get you written up and fired for a major safety violation.. A pile of loose lumber stacked high is not a good tool, that pile gets easier to topple the higher it gets.
Would you personally use a loose pile of wood in your fashion to hold your vehicle up when working on it with no tires? Of course not (at least I hope).
I have a forklift license at work and own a tractor with a front loader at home, I would never consider putting my hands, feet or body under the forks, pallet or my tractor front loader without a very safe and SECURE cribbing THAT CAN'T TOPPLE OR SHIFT.. Nor would I consider your dry stack of loose lumber under the tongue.
Sure, you may get away with it for a long time, but down the road you have increased the chances of Mr Murphy crossing your path.
OP was visited by Mr Murphy and was very lucky to have out smarted him before the trailer slide off.. The tongue falling 10+ inches could have severely damage the trailer A frame or even the trailer frame to the point of it being scrapped..
An extremely costly mistake that CAN BE AVOIDED.
Why take such chances when you can get the proper jack foot extension..
