My scissor steps are not parallel when extended. If I extend them so the middle step is level, the upper slants down away from the camper while the lower one slants back the other way. I always though...
I dont understand scissor steps. They are set up for the camper being a specific height correct? I have yet to observe the camper the same distance from the ground depending on terrain. So how does that work if the back end is higher or lower when usimg leveling blocks front or rear? What about when using the tc off the truck and low to the ground?
