mattyj's avatar
mattyj
Screen Door Part
I'm looking for the screen door handle for my Lance, I even have the part #( Hehr #XDS-8150211 Entry screen door handle) but I cant find it anywhere. I ordered the sliding 12x12 plastic part but cant find this. Has anyone had this problem? Thanks
  • The cross bar door pulls are really nice to use (saves the plastic door slide stop).
    Amazon screen pull/handle
    Was hesitant to respond/recommend, just as well because I also
    thought you were asking about the latch- other than left hand right hand swing, the different mfgs also make matching screw holes difficult-
    The handle/stop for the sliding cover unsure why the stop isn't included when replacing cover. Some (the 2 pieces)are not interchangeable with different brands. Our original slide was a Phillips.
    Screen handle/stop
    Depending on mfg, they refer to the handle/stop with different terms?
    Another standard universal item on most campers that are completely different depending on manufacture.
  • deltabravo wrote:
    Screen door handle:
    Order one of these too.
    I have a spare one of those. They are too wide for my Host door unless I cut it down. I have been too busy/lazy to do so. They fit well on our previous Arctic Fox.
  • I found it on ebay its called a rv screen door 12" sliding bubble stop handle for all of those interested. Thanks
  • Thanks for replies everyone, I'm not being specific enough, on the screen door theres the aprx. 12x12 sliding plastic panel for reaching through the door ( no screen here) and looking out of TC on the left theres a aprox. 11x 2 " plastic strip or handle that you use to pull door shut that broke off. I wish I could post pic.
  • camping word also has them. I replaced mine last month. Be aware that the screw holes may not line up. I found that the latch to the outer door hung a bit to low to use the existing holes on the TC an the screen door for the new latch. So make sure you line up the latch with the outer door and screen door first before you attach the screen door catch to the TC frame. if will save a lot of cursing and redoing....Yeah I was pissed for not checking everything 3-4 times first
  • Etrailer has them. When you go to their site search "rv screen door latch". They have RH & LH. A little pricey-$20+ for each one. In fact I just did a google search for them and found several. Search for the "latch" instead of "handle". Gary
