wmoses
Dec 16, 2013Explorer
I have had no problems using the hollow wall anchors in my post. The trick is to drill the hole very slightly undersized, tap it into place with a hammer ensuring the little teeth bite into the wall, and then tighten the screw to collapse the housing. Worked fine on my Jayco's walls and now my Flagstaff.
Use whatever makes you comfortable, I guess.
