sac89's avatar
sac89
Screws into the ceiling
I have a plastic rail type thing that is screwed into the ceiling holding a curtain (floor to ceiling) that separates the bunk beds to the rest of the camper. Three of the five screws have been stripped out and will not stay when I try to screw them back in.
What can I use to secure this plastic piece going across the top back up to the ceiling? Would a dab of Gorilla Glue or super glue work without staining the ceiling? Clear caulk? Wood glue?
  • keymastr wrote:
    A toothpick wood glued into the hole works.
    Yep, a toothpick, or two usually works well. I sometimes use superglue, wood glue, or epoxy, too. I put the screw in before the glue sets up.
    If it's a big hole, I'll sometimes glue in a wood dowel or something the size of the hole and start all over.
  • RoyB's avatar
    RoyB
    Explorer III
    I always use what is called MOLLY BOLTS. These will screw in and expand behind the wall that giving you lots of strength by spreading out the weight over a larger area. You can also completely remove the screw with this model and the base stays in tact...
    Another popular bolt like this has a spring wing behind the wall but if you remove the screw all drops behind the wall...
    The only other sure method is to put a back board across the area and use regular wood screws to hold up your items...
    Roy Ken
  • they also sell small funnel shaped pieces of window screen for this use.
    bumpy
    Drywall plugs....get some the same length as your screws.
    I had to use those when my fat a** knocked the toilet paper roller off the wall.
