nuckfan wrote:
I installed a Carefree awning on the rear of my TC, they provided butyl tape for sealing between the bracket and camper.
Ah, good info. I'll unbolt the whole thing and place new butyl tape. Thank you.
AnEv942 wrote:
I generally use butyl under any joining pieces, caulk perimeter, bedding in caulk works. The self leveling dicor on vertical surface (wall) may be an issue, its more intended for horizontal surfaces, unless your application will contain it, may flow away from joint or edges. Between what you have seems proflex might be better.
Dicor does have a non-sag sealant, #551 that I can buy. However, with using butyl tape, I'll think I'll use the Proflex on top of that.
