- LynnmorExplorer II
Las Vegas Proud wrote:
It’s a 2016 but there’s spots along the front trim where you can see gaps in the butyl tape like it fell out or something. You can see the wall all the way back behind the trim. The gaps are maybe 1/4 inch to a 1/2 inch long just every so often. I don’t want to take any chances of water getting in there.
Sounds like you are proactive, you're doing the right thing. Water intrusion is the death of a trailer, so stay on top of these kind of issues. - NanciLExplorer III tried Dicor on my last trailer to touch up the seams, and would never use it again.
It is way too sticky and impossible to get a neat bead.
With that said "self leveling" Dicor is great for flatwork like the roof
Jack L - Las_Vegas_ProudExplorerIt’s a 2016 but there’s spots along the front trim where you can see gaps in the butyl tape like it fell out or something. You can see the wall all the way back behind the trim. The gaps are maybe 1/4 inch to a 1/2 inch long just every so often. I don’t want to take any chances of water getting in there.
- goducks10ExplorerHow old is your trailer? You shouldn't have to replace any for years. If you do then you'll just have the same issue the following year.
- Las_Vegas_ProudExplorerThanks all for the butyl tape lesson. I ordered a roll for now and see how far it takes me. I ordered the dicor brand.
- garyemunsonExplorer IIButyl tape is good for about 10 years then should be replaced. Both under the trim and around the windows. In the interim, screw tightening every year will help prevent leaks and prolong the life of your RV. The trim strips can be removed after pulling the "RV Vinyl Insert" out. New butyl tape and new "RV Vinyl Insert" are inexpensive. Lots of screws will come out too easily.. Use toothpicks and carpenter's glue to restore the screw holes so the screws will bite...new screws are a good idea, too!
- FrankShoreExplorer
- beemerphile1ExplorerIt could be Butyl or putty tape. Putty tape is made from clay. It is perfectly normal for it to ooze out over time. Use a plastic scraper to carefully remove the excess. To do a full repair requires removing the entire piece of trim.
If you do remove the trim you may want to consider a relatively new product; http://www.sealdesignllc.com/catalog/seal-tite-corner-seal/ - donn0128Explorer IIButyl putty tape is commonly used between openings and sealing items. Common between windows and walls etc. The stuff is cheap and you can buy it in 50 foot rolls. A plastic scraper will get the old stuff off and cleanmup the joints. Follow it with a bead of Dicor for a good seal.
- Las_Vegas_ProudExplorer2016 Pacific Coachworks Mighty Lite 20RLS is the trailer I have. It does look like butyl tape is what is in the void between the wall and the trim.
