Rbertalotto's avatar
Rbertalotto
Sealing Roof Leak
I have a Palomino Bronco 1200.
Somehow, a very small amount of water finds its way into the very front corner of the overhead.
I thought it was coming in through the bottom of the cloth sides, but today upon close inspection, I see the wood in the roofs corner is wet. So it is getting in through the roof.
There are clearance lights, tie-downs, edge trim, etc that penetrate in this area. Lots of places for a little water to seep in.
So, best way to fix? Spray stuff you see on TV? Remove all caulking and reseal? Something else out there for this?
Any help is appreciated.
Thanks!
  • winniman wrote:
    Best way to find a leak is to either have an air test done, or do it yourself. Pressurize the air inside the rv and use a spray bottle with soapy water around the outside to find where the air leak is.It will blow bubbles when you find it. This is probably where the water is getting in. Saw a thread on how to do your own test. Cut a hole in the side of a storage tote to accept a leaf blower. Turn it upside down over an open roof vent. If all the doors and windows are closed, it should pressurize the rv enough to find the leak. Have not tried this yet, but in theory it sounds like it should work. Good luck.
    What is a good method for pressurizing the inside of a camper?
  • Not sure what kind of roof you have alum or rubber. I have a EPDM rubber roof on my TT. I used Ames Research Maximum Stretch after a coat of primer. I bought their tape and tape the seams/joints/corners and coated over the top. Actually today I did the third coat and I would like to do 5. Essentially its liquid rubber that expands and contracts.I have no leaks! Google for the website.
  • I don't think this will work on a soft side popup truck camper. But thanks for the idea!
  • Best way to find a leak is to either have an air test done, or do it yourself. Pressurize the air inside the rv and use a spray bottle with soapy water around the outside to find where the air leak is.It will blow bubbles when you find it. This is probably where the water is getting in. Saw a thread on how to do your own test. Cut a hole in the side of a storage tote to accept a leaf blower. Turn it upside down over an open roof vent. If all the doors and windows are closed, it should pressurize the rv enough to find the leak. Have not tried this yet, but in theory it sounds like it should work. Good luck.
