ZeeLet50
Jul 24, 2017Explorer
Yes something is loose. The whole front cap piece is becoming unglued. This is causing lots of movement as it heats and cools. There are ripples at the top. If I push on it you can see why it keep pulling the seam apart. So the eternabond tape should suffice? I was wondering if it will hold up under the heat of the sun.
44,068 PostsLatest Activity: Apr 17, 2021
