JimK-NY
Apr 19, 2017Explorer II
FlyfisherBob wrote:
My first test will be with the ProFlex Rv Geocel. Are there any hints for working with this product?
Thanks for all the suggestions so far, keep them coming.
Bob
As I mentioned before, make sure the material is very soft and fluid. If it has started to gel in the tube, it will not stick well. Otherwise it is like any other caulk. The biggest issue to getting an attractive job is smoothing the caulk. You can wet a finger in mineral oil and with some skill you can smooth. Another trick is to tape both sides of the application area. After the caulk starts to harden, remove the tape for a clean line.
