ilvtravln
Apr 18, 2021Explorer II
NMDriver2 wrote:
It is a safety feature for child seats. Do not pull the belt all the way out before fastening it. If you pull it all the way out it is designed to only get tighter and does not allow it to loosen If you only pull it out enough to fasten the belt instead of all the way, then it should allow both loosening and tightening as your body moves.
I tried pulling seatbelt out only enough to fasten it and it works like a champ, I leaned foreward 20X and no problems. Talked to my wife, she says she pulls belt out all the way before she fastens it so problem solved. Thanks
