- mich800Explorer
RWDIII wrote:
hemismith wrote:
mtofell1 wrote:
At some point does the high number of gears in a tranny become an annoyance due to gear hunting? I've heard a few complaints on the Ram 8spd for this. I'm currently in a 6sp which, when I was a kid, was 3 more gears than the best tranny :) 10 just seems ridiculous.
That's what I was thinking. I wonder if they'll skip gears under light load.
I looked up the ratios on the new 10 speed and the ratios of my 6sp(Ford) and in 10th speed I would be going 109 rpm slower 1740 vs 1850
at 68 mph(garmin) 70mph speedo.
Wont be trading the Ford soon:h
There is only so much OD a vehicle can carry before there is a lack of power to hold that gear or downshift. But now you can get lower starting gears and closer differentials between gears helping to keep the vehicle in the powerband or sweet spot for fuel economy. - RWDIIIExplorer
Wont be trading the Ford soon:h - hone_eagleExplorerI bet the 10 gears are to cover as many conditions as possible,light /heavy/ loaded / different speeds /hills etc .
Doubt if if will run through every gear every time. - fireman41Explorer
hone eagle wrote:
Skipping/ starting in a higher gear would not be surprising ,my 12 speed starts in third (load sensing) then 5.7.10 .12.
Better than freightliner, even Bob tailing the highest gear they start in is 2nd.
How many over drive gears is the Ford 10 speed going to have? If it's more than two I think would be prone to hunting more. - notevenExplorer III
Sport45 wrote:
Fordlover wrote:
... But turbos do not an engine make...
Turbos make all the diesel owners proud. :) Without them the oil burners would be the wheezing pigs they used to be.
Personally, I'd like to see Ford add a couple of cylinders to the 3.5 and make a 4.6 ecoboost. With 15# of boost it would have the sea level performance (and gas consumption) of the old 460 at any elevation while maintaining the unloaded economy of a small block.
V10 EcoBoost 600HP! - hone_eagleExplorer
Skipping/ starting in a higher gear would not be surprising ,my 12 speed starts in third (load sensing) then 5.7.10 .12. - Turtle_n_PeepsExplorer
Why on earth would you want to downgrade to the HP of a 460? The Ecoboost makes 100 to 150 more HP then that old boat anchor. In fact the Ecoboost already makes more HP then almost any big block ever put in a truck. - hemismithExplorer
That's what I was thinking. I wonder if they'll skip gears under light load. - hemismithExplorer
Agreed. - mtofell1ExplorerAt some point does the high number of gears in a tranny become an annoyance due to gear hunting? I've heard a few complaints on the Ram 8spd for this. I'm currently in a 6sp which, when I was a kid, was 3 more gears than the best tranny :) 10 just seems ridiculous.
44,067 PostsLatest Activity: Jun 05, 2026
