Gdetrailer
Mar 26, 2017Explorer III
westend wrote:
Yes. On some assemblies the adjustment lever can be bent or spacers used so it is moved out from the star wheel so it doesn't make contact. With some assemblies it may be possible to remove the adjusting cable and the adjusting lever entirely. It depends on how the assembly is built.
There is really nothing inherently wrong with the self-adjusting assembly. I don't know what has spooked you into changing them.
I recall seeing some posts that the OP started where several folks mentioned that the self adjusting managed to over adjust?
I personally think that those folks who made that claim did not initially adjust the brakes correctly.
I HAVE driven a lot of vehicles from the 1970s which had DRUMS on all four wheels, I can honestly say that I have NEVER, EVER encountered any such problem with drum brakes..
I have however encountered problems with the self adjusters FAILING to "adjust" as the brake shoes wore.. This would be noticed especially when it was the front drums as a pulling to one side or the other on the steering wheel..
There is no way self adjusters can over tighten, the design is simple, nothing more than a cable strung to a lever, the lever gets pulled slightly when the brakes expand..
The lever drops slightly when the brakes release.. The lever can only move the adjuster when it catches one of the "stars" on the adjuster wheel..
If the brakes are tight enough the adjuster lever will not catch a star and slide by it.
Not sure what folks are doing that they "need" to make so many adjustments on trailer brakes to warrant self adjusters.. I have adjusted mine ONCE in the now 10 yrs of ownership of my current trailer. That was when I bought new drums to convert from the old Dexter "star" rims to modern 5 bolt Ford pattern rims.
As far as I can tell, they ARE the original brakes on my trailer, not sure how many miles it has but it was bought in California and some how found it's way to PA.. My trailer is a 1984 vintage..
Just bought a new set of backing plates/brakes for it, will be putting them on in a couple of weeks. Bought standard non self adjusting, to me not worth the additional upcharge in cost..
The only reason for me to replace was last inspection the mechanic found some cracks in the lining at the bottom of one of the brake shoes.. Most likely will not pass inspection this year..
44,066 PostsLatest Activity: Apr 10, 2026
