westend
Mar 27, 2017Explorer
js6343js6343 wrote:No worries. My question about the hubs was directed to Gde.westend wrote:Gdetrailer wrote:
That was when I bought new drums to convert from the old Dexter "star" rims to modern 5 bolt Ford pattern rims.
Did you replace the hubs, also?
I've found the biggest failure of brake assemblies has been either a buildup of dirt through open adjustment ports on the backing plate or no lubrication on moving parts when installing. I wish I had a dollar for every star wheel and threaded rod I've had to tear down and lubricate.
I replaced the entire backing plate with self adjusting brakes. I did not replace the drums.
My suggestion to the OP is to make sure a lubricant is put on moving parts and try the new brakes out. You may be assuming a problem that doesn't exist.
44,066 PostsLatest Activity: Apr 10, 2026
