Gdetrailer
Mar 27, 2017Explorer III
Lynnmor wrote:Gdetrailer wrote:
An out of round drum causing problems is NOT the fault of self adjusters, period.
An out of round drum is easy to find, heavy vibration while braking is one sure sign that a driver WILL FEEL even as far back as the trailer axles..
Another sure sign of out of round drums is the brakes lightly dragging then no drag or complete stop while turning wheel or drum when you have the tire off the ground during your own inspection (you DO periodically INSPECT your drums/brakes, DON'T YOU??? I sure do!).
PA has an annual inspection, so I CHECK MY OWN BRAKES BEFORE DRAGGING THE TRAILER TO THE INSPECTION STATION. Saves time and aggravation of a failed inspection.
I am in PA as well and hate having anyone mess with my brakes, bearings and seals. My vehicles get three inspections per year. First I inspect, second the inspection and third I fix what they touched.
Yes, I do all of my own work including the turning of brake drums. The idea that over-adjusting is not the fault of self-adjusters, you have to remember that the axle manufacturer often turns out poor quality. Folks that want the self-adjusting feature are just trying to get out of one more chore and they will never detect the grabbing of the brakes because they will never check.
Perhaps "owning" a RV is not for you?
Don't trust the inspection mechanic, simple, MOVE ON TO ANOTHER.
I drive 15 miles one way to mechanics that I found are straight shooters good.. There are MANY "inspection stations" to choose from, just a matter of finding one that has constantly good mechanics.
I found mine at a local tire shop which does not only passenger vehicles but also heavy truck tires and mechanicals.. GOOD folks there.
I also stand right there while they inspect, they give me tips and pointers and I can give them the history of what has been done.
Don't trust, don't take it back and find another mechanic.
Not ALL mechanics are bad, there ARE good ones, just have to sift out the bad ones.
44,066 PostsLatest Activity: Apr 10, 2026
