carringb wrote:
Old-Biscuit wrote:
Rotating 5-6 turns before stopping is 4-5 turns to many
They are NOT too tight..they are too loose.
Need to adjust them for 3/4-1 turn and then burnish them in
I was assuming 5-6 turns without the brakes engaged. If thats with the brakes engaged, they are way too loose, possibly so loose the adjusters can't start clicking over, since there needs to be enough drag to tug on the adjuster cable.
That is correct 5-6 turns as you roll down the road.. with a slight sound of pad to drum sound... ... once the brakes are engaged , they stop .. right away. . I was over there last night...
