Ramblin__Ralph's avatar
Aug 31, 2013
Separation at tie down eye
When I bought my 845 used almost 8 years ago, it had a slight separation at the passenger front tie down eye area. After 70K+ miles on my truck it is much larger.
What's the usual "fix" for this?
Note: Going to replace some tape I had over this area to prevent leaks.
Thanks,
  • As popeyemth said about adding metal structure, but you may need to do it on both the inside and out. You will need to access as much space on the inside in order to install steel that is as long and continious as possible to repair the framework. I ended up removing my water heater and furnace to gain inside access.
    I had a similar issue on an old camper. I used 2"x2" angle steel at the inside corner with PL-400 adhesive and carriage thru- bolted 1/8" x 2" flat steel on the underside for the 8' length of the side. Below is a drawing cross section of how I installed the steel structure:
  • A large piece of thick aluminum bolted through the bottom into the frame and inside the camper likely will pull this back flat
    You have a broken wooden frame member there and need to span across the remaining good frame on bothe sides of the break to support it
    Good Luck, Mike
