Adam_H
Jul 15, 2017Explorer
Gdetrailer wrote:RinconVTR wrote:
I posted the same write up in the Tundra forum but felt it belonged here as well as so many people ask about towing with their SUV.
2010 Toyota Sequoia Limited with 155,000 miles
ATF changed out every year, all other fluids kept fresh as well.
LT tires, Bilstien shocks all around, rear spring spacer.
2017 Grand Design 2800BH with shock kit and Hensley hitch. Gross weight fully loaded is 7100lbs with a tongue weight of 960lbs. Again that's fully loaded, with some amount of fresh water, and the Hensley hitch with 1400lbs bars.
Wisconsin to many parts of Cali and many stops in between.
6934 miles total
5,000++ miles towing, including towing to/from/thru Yosemeti, Rocky Mountain NP, Death Valley.
We were towing and pulling thru mountain hills at temps well over 100 multiple days, many days were around 115. Death Valley day was 121.
I'll be very frank, I could not tow this trailer without the Hensley (or Propride) design hitch. I used to tow a 24' trailer with the Sequoia (Honda Pilot too!) and did very well. But one day out of the blue I opted to try the Hensley and never went back. There is simply no comparison.
IMO, anyone feeling they need a bigger truck to tow their in weight spec travel trailer, try one of these hitches before you throw down on a bigger truck or dump your trailer! They have a 60 day trail period, you would only loose about $150 to ship the unit back if you found its not for you. Make no mistake, there will be things you hate about it, but you will absolutely love towing with it. Best of all...you get to keep your favorite 1/2 ton or SUV...and/or avoid buying a dedicated tow vehicle.
EDIT: Additional info;
- Rear camera on trailer is now a requirement for me.
- Brake controller is a Prodigy P2 with "boost option" set on B3.
Vegas baby...
Near the 12,000ft peak of Rocky Mtn NP...
Your "gleefulness" of your "demonstration" of just how "good" your borderline over specifications rig is really saddening if not a bit sickening to me.
It really SHOULD be more like "FOLKS, DO NOT TRY THIS AT HOME" type of demonstration.
You have been LUCKY, but keep in mind, one day, MR MURPHEY WILL come to visit you.. And on that day, YOU may not be so lucky.
I HAVE been visited by Mr Murphy not once but TWICE with DEER running right in front of me while towing a trailer loaded at about 6500 lbs while driving 68 MPH.
Fortunately for me and my family I INTENTIONALLY chose to go with a much more capable tow vehicle than what you have.. I have been towing TTs for 15 yrs now and my vehicle of choice at a minimum is a 3/4 ton truck..
My current truck has 3415 lbs of CARGO capacity and my 860 lb tongue weight is nothing for my vehicle to handle, in fact, I go bare foot without WD or sway control..
BOTH times I never lost control or even felt like I was going to lose control.. BOTH times I was able to maintain full and complete control of the vehicle and trailer. BOTH times I never left the lane, no sway, not even a slight hint..
IF I had YOUR setup (including your HA hitch), the outcome would have been pretty grim to fatal for not only the deer but myself or my family.
Marginal setups like yours can be "made" to work under NORMAL CONDITIONS (IE sunshine and no obstacles) but when presented with bad weather or emergency maneuvers like a deer darting in front of you or a car stopping in front of you all bets will be off.
I should know about marginal setups, used to tow a utility trailer with a small car before I had a TT, was not fun and fought me all the time..
It wasn't until a bought a pickup truck and discovered a whole different world of towing that was not a fight..
I simply did not know better until I had a much better suited tow vehicle.
My post comes from the voice of experience, I have been there, done that with an overloaded tow vehicle.. I will not go back to that.
You gotta be kidding me. He stated he wasn't over loaded and towed over 6000 Miles in one shot. Nothing "marginal" about it and after this trip he has already proven you wrong.
I suppose he should've bought an F550 to tow with. Sheesh, get real...
