work2much's avatar
work2much
Service Temporarily Unavailable
I'm sure I'm not the only one experiencing this intermittent glitch on RV.Net
There used to be some different portals to this forum. Does anyone know if they still exist, what they are and if they are having the same issue?
Thanks!
  • Yes it is a problem. Tried to post and and some pictures... Pure hell!
    Never seen this forum be so bad!
    Strange that is has not been fixed.
    Jim
  • this has been going on and off for over a year now. they don't care.
  • You would think that maybe someone at GS could actually fix this. Maybe they don't care about their customers and forum users that much.
  • The Good Sam Portal seems to be faster than rv.net too
  • ykphil wrote:
    Try from here:
    https://forums.motorhome.com/index.cfm/fuseaction/thread/tid/29887572.cfm
    This seems to work as well.
  • d3500ram wrote:
    Just hit your browser refresh button and it should come up... at least that is how it works for me with no down time or trouble other than needing to hit that button.
    The only exception or issue I had was when replying... I hit the refresh button a few times and a quadruple posting of the same reply.
    Yes, I noticed that. Sometimes needing to refresh several times. So far using the Good Sams avenue hasn't had an issue. You will need to enter your password, at least I did to post on Good Sams portal.
  • Try from here:
  • Just hit your browser refresh button and it should come up... at least that is how it works for me with no down time or trouble other than needing to hit that button.
