parker_rowe
Sep 25, 2020Explorer
Yosemite Sam1 wrote:Bedlam wrote:
Most automatics do lock the torque convertor in first gear, so I suspect anyone using that gear for sustained periods of time is building up a lot of heat. If second cannot hold you, you are traveling to fast for the amount weight you are towing.
I would suspect that too. Was not able to follow up whether the trailer is pushing his TV beyond the upper most speed range of the 1st gear, then I would imagine he would get a worst tranny problem than just overheating -- although the group has full trust and confidence with the Toyota/Japanese engineering excellence, loll.
I don't think the transmission is even going in 1st. The engine would be way overspeed in most situations unless you were going super slow.
Most modern transmissions will only downshift as far as the computer deems safe. It wouldn't surprise me if people just slam the lever in 1st thinking that is where the trans is shifting, when really they are in 3rd or second.
44,065 PostsLatest Activity: Apr 14, 2026
