CardinalsExplorerAug 03, 2015Sewer DrainWhen I go to drain the black water tank the slide out device is very hard to pull out. I have used two types of lubricants on it to help "it slide" but to no avail. Any suggestions, the waste water ...Show More
coolbreeze01ExplorerAug 03, 2015Where are you applying the lubricant? WD-40 on the push/pull bar makes mine work better immediately. There is arguably better grease available.
Related ContentHouse battery drain100' sewer drainSewer drain is lower than the dump drain.Sewer Drain HosePower Drain
