ddrueckh
Dec 13, 2014Explorer
It should not be glued on. They are threaded. I thought mine was glued, but realized it was screwed into a union fitting. I was trying to unscrew the union instead of the valve (the union is glued to the pipe). The valve in a male and the union is female. When you try to unscrew it, try turning from the top. It should be pretty easy to remove.
