krobbe
Sep 02, 2013Explorer
c3saving wrote:
We were highly concerned when we watched it smoke and then one of the wires turned red. At that point, we shut all breakers off, and unplugged power from the outside pedestal. We have an extended warranty with Precision. Hopefully, the money spent on that coverage will save us from a huge bill. The one year warranty was up on June 1st. I'll give a call to the dealer tomorrow. I did have a conversation with an electrical engineer. Although he has not seen the picture, he said the bus and wires should be replaced because the heat probably altered the wires. I'll look at one of those surge suppressors. What's the worse case scenario, so I can be prepared.
If only the Neutral bar needs replacing, they're about $10-20 max. An all new 35Amp service panel is about $200. Hourly rates will greatly vary. Hopefully there is enough extra wire behind/underneath the panel to simply pull a little more wire into the panel if needed so the repair time is minimal. If you're thinking of adding the surge suppressor, now is the perfect time if someone is already working on the panel. :)
44,066 PostsLatest Activity: Mar 14, 2015
