josiescott wrote:
I'm going to test that out. I read it takes a lot of battery juice.
not as much as running the furnace overnight. unless you have low batteries, you should be able to run the slide out without using too much battery power.
of course, if you only have one battery and don't conserve power, you could end up with a dead battery after one night.
if you plan of doing more dry camping, you need to go to a dual battery setup.
we dry camp 90 percent of the time so we have the dual batteries plus a Honda 2000i generator.
plus it would help if you posted year/make/model of hybrid, since you don't have it listed in your sig line.
makes a difference in how to manually put the slide in.
