- Timmo_Explorer IIIf one does not need the "weight distribution features" the bars provide, then why connect them for short moves? I relocate my TT about 3-4 times a year on the property, I just drop the tongue on the hitch ball and TCB (Aretha Freanklin, Respect). While backing, I must negotiate a sharp jackknife-like turn to square the TT away.
- KalabinExplorerI'm another that has to do a 90 degree backing with about a 15% grade to get into my driveway. I always pull up straight with my house, hop out and disconnect my bar's and then jack knife it and back up my driveway.
Main reason for removing the bar's is with them on the rear of my trailer would hit the driveway, without them on it gives the trailer a lot more play to move with the grade. - lane_hogExplorer II
'tiredTeacher wrote:
Do you remove (or not install) the bars when pulling out of the driveway? How is pulling out different from backing in?
For the first couple trips on our sharp turn drive, I did just that -- removed the bars. Now I don't worry about it, and the hitch is just fine albeit noisy. - HuntindogExplorer
Generally one will not obtain as sharp of an angle going forwards.
I'm no trying to be a smart ass. I've just noticed folks look at backing as a separate maneuver from driving forward. Isn't it the same path for the wheels? Do you remove (or not install) the bars when pulling out of the driveway? How is pulling out different from backing in?
Teach
I had one TV TT lashup that could make contact when making a U turn going forwards. It was my first setup. A 1973 blazer towing a 24'prowler. That was not a very good setup for towing though. The short wheelbase that allowed the contact in a U turn, also made for a pretty unstable tow. It was long before the internet, and one generally learned such things then from experience. - _tiredTeacherExplorer II
Lynnmor wrote:
You need an Oldsmobile Tornado.
I'm old enough to have seen that commercial on TV and it was a Toronado. - _tiredTeacherExplorer III'm no trying to be a smart ass. I've just noticed folks look at backing as a separate maneuver from driving forward. Isn't it the same path for the wheels? Do you remove (or not install) the bars when pulling out of the driveway? How is pulling out different from backing in?
Teach - LynnmorExplorer II
LVJJJ wrote:
Once when backing into an uphill camp site, the bars took so much weight off the rear tires of the TV that it lost traction part way up. Had to roll back down and remove bars first.
- RHasseExplorer
MikeDupont wrote:
Wow, all these years with a Equalizer and i didnt realize i had a problem until now. Maybe i dont back up at what you all are referring to as a 'sharp' angle.
Same here... - lane_hogExplorer III do a 90* backup turn into my driveway off a state highway, and never remove the bars on my DC...
- MikeDupontExplorerWow, all these years with a Equalizer and i didnt realize i had a problem until now. Maybe i dont back up at what you all are referring to as a 'sharp' angle.
