Grit_dog
Jul 30, 2020Trailblazer
silverbullet555 wrote:
Some good points. I think it might end up being a combination of solutions.
I have a sprayed in bed liner and no mat. Currently, the camper rides on a 2x4 platform made by the previous owner. I am only using it because I need the space to use the brophy mounts. Once I finally convert over to either happijac or torklift I will no longer need the riser for that purpose. Then I'll have to see if I need one to clear the cab on the truck.
This is why it’s sliding around. But you could shim it tight. Problem is you gotta load it the same to whim it the same unless you have a bunch of say 1/2” plywood rips.
44,070 PostsLatest Activity: Jul 01, 2022
