woodhog
Sep 02, 2017Explorer
Shock Time?
The outfit below seems to be bottoming out much harder than it used to this season. Pot holes or sharp bumps in the road produce very jarring results,very quick rates. The shocks are Bilstein ...
woodhog wrote:Check the rubber bushing at the bottom of the front shocks for wear . Early Bilsteins had a problem with them wearing prematurely and came out with a new design . I called them and they sent 4 New front shocks (2 trucks) and did not have return the old ones , which BTW had the same dampening feel as the new ones after almost 100k miles . You do have to remove to test for dampening . Good luck .
this season.
quick rates.
The shocks are Bilstein 5100's and have been on the truck for
about 8 years, they show no sign of leaking.
Tires are 75psi front and 85psi rear.
Ball joints seem good, the whole thing weighs about 11,000lbs Gross.
I don't know of any method to test them properly.
Thanks
