Mike_Up
Aug 05, 2013Explorer
Two Hands wrote:
My son has finally gotten the bug to buy a trailer. I could sure use your help to assist him in finding one. Their family consists of him, his wife, and four children age 13 and under. He is 6'7" so light and ulta light trailers don't have the head room he needs. He thinks a unit with bunk beds and one slide might be best. They don't want a tent trailer or pop-up, but would consider a hybird (I think that is the one with tent ends). He must keep the loaded weight under 8100 pounds. Any suggestions would be greatly appreciated.
Since he's 6'7", you're right, there's not enough headroom in most none stick and tin/aluminum sided trailers. Most that use the sandwiched laminated foam walls with 1/16" fiberglass on one side and 1/8" decorative board on the other normally do not have enough headroom unless you go with a premium trailer like a Jayco Eagle. Those will be super heavy and require minimum 3/4 ton truck. The Jayco Eagle Travel Trailers are huge and have a 84" (7') ceiling.
So if he doesn't have or will buy a 3/4 ton truck, I wouldn't consider.
Or he could get a great quality build in a Jayco Jay Flight that has 6'9" ceilings and the weight is lighter but models with slides will border on needing a 3/4 ton truck depending on if it's just him and wife or a fully family and their gear.
I chose the none slide model Jay Flight 26BH because I'm not a fan of slides( I like the KISS theory), plus the slides add a lot of un-necessary weight.
Once slide model that still fairly light is the Jay Flight 28BHS but I didn't find it much more roomy than our 26BH and actually like the 26BH floorplan better. So we bought the 26BH. The next model that I liked but was heavier than I wanted, plus didn't have a double bed but single bunks, was the Jay Flight 25BHS. It shorter but has a super slide that's full depth. The 28BHS is a small sofa slide with only half depth.
However with the Jay Flights, he'll only have 2" of clearance which would be pretty claustrophobic. I know, I couldn't stand being in an Ameri-lite because the ceilings were so low. I'd go crazy in there.
My cousin is 6'8" and I recommended he go with a High wall pop up as they offer more headroom than any other trailer but are just as pricey as mid-level travel trailers.
BTW, Jayco's standard pop ups have a 7'1" ceiling which is pretty good. Unfortunately Palomino, Viking/clipper, and Jayco have discontinued their High wall pop ups.
However looks like Jayco's other brand, StarCraft, has started making their own individual floorplans instead of cloning the Jaycos. This is a great thing and while Jayco no longer has a Highwall, StarCraft does. It's the Comet 3611HW and has a 84.5" (7'.5") ceiling height while providing many travel trailer amenities.
Forest RIver's Flagstaff/Rockwood brand still has highwalls but they have no interior ceiling dimensions and I don't recommend these because of inferior quality control and build. Had one that literally fell apart just from sitting and quality of build was subpar to all competition. However Palomino and Viking/Clipper are now Forest River so they should be no different.
I know you said he doesn't want a Pop Up but as tall as he is, he's either got to have some money to buy an Eagle and a 3/4 ton truck or bring his standards down to a pop up, if he expects to stand comfortably in the trailer.
