CA_Traveler
Jul 29, 2016Explorer III
wowchad wrote:Isolation is the name of the game!: ALL CBs off, plug into GFCI, main CB on and if no tripping continue with each CB one at a time. Usually this will ID the failing circuit which is often water related as in HW, refer, outside plug or plug near a sink. Then isolate the problem on that circuit.
Our TT started doing this exact same thing!
Non-GFCI outlets or by using the 30 amp cord it's completely fine, no problems & no tripped breakers.
But I'm popping every GFCI outlet I plug into.
44,071 PostsLatest Activity: Aug 30, 2026
